how to create Datum CSYS with NX open
how to create Datum csys with NX open code
Re: how to create Datum CSYS with NX open
To get started you can go through http://www.nxjournaling.com/forums/journaling-nxopen-api .
Best Regards
Kapil
The quick way to get working example code is to start the journal recorder, perform the operation of interest, stop the journal recorder, and examine the output code. The recorded journal code may not be the most concise, but it is a good starting point.
