how to create drafting note in current view plane
I am using Nx 11.By using NXopen api I have created a point UDO and I have created a drafting note attached to that point_UDO
as shown in attaches image.png  i.e part(A)
current situation:
 when I ratate view drafting note also rotated w.r.t view.
as shown in image.png  i.e part(B)
requirement:
 when I ratate view drafting note should always be in current view plane i.e on screen plane.
as shown in image.png  i.e part(C)
I want to know that is it possible by programming?if yes please tell us how to do that..
thanks
Re: how to create drafting note in current view plane
Have you thought of using temporary display objects instead of a Note?
Note that I haven't actually done this, but the idea is to register a DisplayCallback for your UDO and in that callback display whatever you want to indicate data about the UDO. To display text you can use UF_DISP_display_temporary_text() which always displays the text on the viewing plane.
In UF_DISP there are a number of other functions that allow display of arcs, lines etc so you can construct geometric shapes as well as text.
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.0.27 MP1]
can you please explain with sample project code?
So, no sorry I can't supply any code to show how it works.
But if you go to the Solution Center and search for nx_api4898 there is a C# example there.
