how to flexibility transfer element label from post to pre
If i find some elements's stress are very big in post view,i need to check propertys of these elements.how can i transfer these elements's label from post to pre except manually cope these elements's label and paste them to pre. Moreover,Select controls in Block UI Style can't use in post view,how can i create interface like post function.
Re: how to flexibility transfer element label from post to pre
Does it help to create a group with identify results function?
Xtof
This method is not very convenience. How can i change mouse to select status when user enter myself interface like enter Indentify result function?
then i can get user selected elements like "clear selection" function.
