how to get tool list with the help of NX open code ?
Hi ALL,
Need a help in getting the tool list from nx open code (preffreably c#). I want the name of all the tools available as used/unused in machine tool navigator . The tool name should get output in listing window or a separate txt file.
Re: how to get tool list with the help of NX open code ?
There is an example program on the Solution Center that might be a good start, called
Sample CAM Visual Basic program : report all cam tools
This link may work:
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&p=1&q=nx_api4709&file_t...
If the link does not work, just search for "nx_api4709", and it should find it.  (It is VB, not C#.)
I am not sure how to cycle the machine tool navigator.
In the operation navigator, you can either cycle tools, or cycle operations and ask for their tool parents. If you want both used and unused tools, you need to cycle the tools.
Here is another sample api program - it cycles the operations, and reports with parent and reference tools are used:
' GetToolCycleAllOps.vb
'   Copyright 2015 Siemens Product Lifecycle Management Software Inc. All Rights Reserved.
'  REVISIONS
'     03-Aug-2015  Mark Rief   Original
'   DESCRIPTION
    ' This program will cycle through all the operations in the tool view and
	' report their tools used.
Imports System
Imports System.Collections
Imports NXOpen
Imports NXOpen.CAM
Imports NXOpen.UF
Imports NXOpen.Utilities
Public Class report_all_oper_ref_cutters
    Public Shared Sub Main(ByVal args As String())
        Try
            Dim theUI As UI = UI.GetUI()
            Dim theUfSession As UFSession = UFSession.GetUFSession()
            Dim dispPart As Part = theSession.Parts.Display
            Dim lw As ListingWindow = theSession.ListingWindow
            lw.Open()
            Dim opers As OperationCollection = dispPart.CAMSetup.CAMOperationCollection
            Dim en As IEnumerator = opers.GetEnumerator()
            en.Reset()
            While en.MoveNext()
                Dim oper As Operation = DirectCast(en.Current, Operation)
                lw.WriteLine(oper.Name)
				'Get the parent in the tool view
                Dim toolGroup As CAM.NCGroup = oper.GetParent(CAM.CAMSetup.View.MachineTool)
				'Only tools (not pockets, Unused items, turrets, heads)
                If TypeOf toolGroup Is CAM.Tool Then
					Dim cutter As Tool = DirectCast(toolGroup, Tool)
					lw.WriteLine(" Tool Parent: " & cutter.Name)
				Else
					lw.WriteLine(" No Tool")
				End If
				'Also look for reference tool
				Dim ref_cutter_tag As Tag = Tag.Null
				theUfSession.Oper.AskRefCutter(oper.Tag, ref_cutter_tag)
				If ref_cutter_tag <> Tag.Null Then
					Dim ref_cutter As Tool = DirectCast(NXObjectManager.[Get](ref_cutter_tag), Tool)
					lw.WriteLine(" Reference Tool: " & ref_cutter.Name)
				Else
					lw.WriteLine(" No Reference Tool")
				End If
            End While
        Catch ex As NXOpen.NXException
            ' end try
            UI.GetUI().NXMessageBox.Show("Message", NXMessageBox.DialogType.[Error], ex.Message)
        Catch ex As Exception
        End Try
    End Sub
End Class
