how to read NX env variables such as UGII_PYTHONPATH using ufunc program
Hi All,
I am trying to read the UGII_PYTHONPATH env variable using ufunc program.
If I use  C method
pathValue = getenv("UGII_PYTHONPATH");
 it returns NULL.
Can you please let me know if there is any way to do this.
Ramesh
Re: how to read NX env variables such as UGII_PYTHONPATH using ufunc program
The C stdlib getenv function can only return environment variables defined on OS level like Control Panel but it cannot return the environment variables defined in UGII_ENV_FILE.
If you want to use the legacy Open C, the Open C Reference Guide provides a (full text) search to find UF_translate_variable in the uf.h section and examples can be found with a Solution Center search.
For the newer NXOpen C++ API you may prefer GetEnvironmentVariableValue or other language derivates.
Thank you Beetle for the answer.
