how tp export drawing as pdf & name it by part attribute or string expression
Hello all,
I need your help to name pdf files by using existing part attributes or string expressions.
I need this for native nx 10.0
I have been exploring but unable to find a way, any help is greatly appreciated.
Thanks in advance...
Re: how tp export drawing as pdf & name it by part attribute or string expression
Gears Legend Gears Legend
Gears Legend
You can find the code on www.nxjournaling.com
Patrick Delisse
KMWE - DutchAero
NX 12.0, TC 11.2, CAMPOST V22, Vericut 8.1, TDM 4.8
C#, VB, .NET
Can this be done in Teamcenter Integration too?  by default, NX names the PDF files with DB_Part_NO, but I'd like to change that to DB_PART_NAME, or use a string of attributes that create our 'smart' part number.
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Thanks Patrick, I am checking it on the link.
Hi Dave,
Can you tell me how the filename should look like? Which attributes do you want to combine?
I'll send you a journal to export all sheets of your part into a pdf.
br
Fred
