is it possible to get category of expressions?
I have all the expressions from a part in a array and want to filter the expression using its type e.g. "User Defined". Is there any way to do so? Till NX 8.5 there was nothing like this.
Re: is it possible to get category of expressions?
Esteemed Contributor
The filter is just a regular expression match on the expression name.
Any expression name not matching the pattern "p\d+" is user defined for instance.
You will have to build your own filter using regular expression matching.
Honored Contributor
Honored Contributor
It seems to be more than just name pattern matching; if you create a new part and manually create a new expression named "p9" (or any name that matches the "p\d+" pattern) it will show up as "user defined". Also, the API offers different methods to .CreateExpression or .CreateSystemExpression. NX must somehow flag the user expressions (and/or system expressions) to differentiate them.
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
I have a similar problem in NX10.
It appears I can cycle through all expressions in the part. However, I can't programmatically differentiate a system expression.
I tried it as locked expressions, but I can as a user lock an expression.
What does VisibleExpressions get? Does it get all the unlocked expressions?
MAYAHTT
www.mayahtt.com
