isObjIntsctZone
when I try to call isObjIntsctZone method in Java it gives me this error:
Exception encountered: Internal error: an attempt was made to access an attribute not in the relevant class
nxopen.NXException: Internal error: an attempt was made to access an attribute not in the relevant class
at nxopen.uf.UFFltr_impl.isObjIntsctZone(Native Method)
I use this command:
boolean touchesBox = UFS.fltr().isObjIntsctZone(boxSize, c[i].tag(), c[j].tag());
UFS is current UFSession, boxSize is double and c's are Component type objects.
What am I doing wrong? Please let me know if you have any idea.
EDIT:
isObjInsideBoxZone works fine for example.
Re: isObjIntsctZone
I am experiencing this exact issue. Have you found a solution?
NX 9.0.3.4 MP13
VB.net
Visual Studio 2015
