keep selected components
I want to check each component in assembly, if specific attribute exist.
If yes - components should be selected and when application terminates, components should stay selected (not only highlighted).
Any hints how to achieve this?
Marcin
Re: keep selected components
I have the same problem.
It seams this is only possible to get access to the Selection Manager if you use a BlockStyler- or UiStyler dialog.
My work around is to create a component group with a specific name and add the matching components to this. So it is easy to select those components interactively by selecting the component group.
Make sure to clear / delete an already existing component group before you cycle the components.
Hope this helps.
Would be great to get access to the selection manager generally / with a WinForm.
Herbert Macho
EBNER Industrieofenbau
AUSTRIA
NX10.0.3.5 (TeamCenter11 and Native)
