nxopen.face
selected face is planer
i want to extract surafce which is planer and same like face or it would be good having copy of face
is it possible plz reply
Re: nxopen.face
In interactive NX, record a journal while using the extract face command (menu -> insert -> associative copy -> extract geometry => change type to "face" and set the "associative" option as you desire). The returned journal code will show you which API calls you will need to make the copy.
Re: nxopen.face
Thank you very much
