open part dialog in NX managed session
Does anyone here knows how can I open the below attached open part dialog while working with NX managed session(TCE NX session) ? I am trying to do this using NX Open or UF wapper API's with c# .
Re: open part dialog in NX managed session
Esteemed Contributor
I think the UFUi method AskOpenPartFilename can be used for this.
Have you tried to record a journal to get the new method instead of using the wrapper?
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.7 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
After some trial and error I found the solution. Use the below mentioned API and you should be able to launch the open part dialog box.
 TheUFSesssion.Ui.AskOpenPartFilename(ref strCompSpec, ref bUnused, out resp);
Hello Stefan,
Thanks for the reply. I was able to launch the UI using AskOpenPartFilename. Using journal does not tells you which builder class you should use.
