resultParameters.SetElementValueCriterion() : Tensor and Derived Component ?
When you chose to active the absolute value with :  resultParameters.SetAbsoluteValue(True)
And then, using : resultParameters.SetElementValueCriterion()
--> What is the difference between those two parameters :
- CAE.Result.TensorDerivedAbsolute.DerivedComponent ? (Derived Component parameter)
- CAE.Result.TensorDerivedAbsolute.TensorComponent ? (Tensor Component parameter)
Best Regards,
Baptiste
Re: resultParameters.SetElementValueCriterion() : Tensor and Derived Component ?
According to the doc
CAE.Result.TensorDerivedAbsolute.DerivedComponent is absolute value of derived component without changing primary components.
This corresponds to the enumeration seen at the bottom of the interactive Element Plot dialog:
See "Absolute value calculation method" in the online help for the Set Result dialog box:
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#goto:advancedSmiley Tongueost_select_results_op
