saving part file in NX blockstyler button click
 Hi All,
I am running my NX application which has blockstyler dialog, on new NX session. I am trying to open a part file and save it after adding some expressions (without doing any operation also gives error) by clicking a button in blockstyler dialog. I am getting error “An operation is performed that deleted the undo mark created by dialog framework such operation should be performed in OK or Apply callback … … … ” and closes the blockstyler dialog.
Is it not possible to save part file through click of button in blockstyler, is there any method to save file on button click.
I am using NX 8.5.2.3, NXopen C++ API, BlockStyler dialog
Error message screen shot attached
Thanking you
Nij
