size of dimension
I need to change the size of text and number of decimals are all dimensions in a drawing.
Thank you very much
Re: size of dimension
What version of NX?
NX 9.0
I'd suggest recording a journal while making the desired changes. The journal recorder coverage is pretty good in NX 9. Once you have the recorded code, you can generalize it so that it applies to other dimension objects in other part files.
