sketch customization nx9
I'm looking for a setting I used in previous nx versions. I found something but it behaves not the same in nx9. Maybe there is some thing to learn.
In pre nx9 version I used the autoplacement option for sketch dimension as default setting.
To tell you why, because the dimension will placed relative to the line or  other geometric object.
Moving, dragging the sketch contour will move the dimension,too. This will avoid reworking the sketch dimension placement after dragging. In nx 9 I used the autoplacement option, but the discriped workflow doesn't work anymore. Did I missed something, new option I do not know?
thank you in advance
uwenx
