syntax to use RSEvent.GetResultFileName()?
to all
I am trying to use the option RSEvent.GetResultFileName() to return the .afu file associated with the event but failing miserably.
Could someone poinyt me in the right direction?
Dim RespSimSolFound As CAE.ResponseSimulation.Solution
	For Each myRespSimCol As CAE.ResponseSimulation.Solution In theRespSimManager.Solutions
		theLW.WriteLine("Resp Sim Name is:" & myRespSimCol.GetSolutionName)
		For Each myRSEvent As CAE.ResponseSimulation.RSEvent In RespSimSolFound.GetEvents
			theLW.WriteLine("  Event Name is:" & myRSEvent.GetEventName)
			Dim thefileType As CAE.ResponseSimulation.RSEvent.ResultFileType = CAE.ResponseSimulation.RSEvent.ResultFileType.FunctionResponse
			Dim sTheAFUFilePath As String = IntheRSEvent.GetResultFileName(thefileType)
			theLW.WriteLine("  AFU File is:" & sTheAFUFilePath)
		Next
	Next
Re: syntax to use RSEvent.GetResultFileName()?
Assuming that there are no copy/paste errors in your example, where did "IntheRSEvent" come from? The RSEvent objects you're looping over are named myRSEvent.
Change this:
 to this:
Dim sTheAFUFilePath As String = myRSEvent.GetResultFileName(thefileType)
that's me not paying attention (at all!). Rather embarrassing. Thanks a lot
