ug_clone with mapping
with Teamcenter I usually use ugmanager_import with a mapping file to either rename complete assemblies or carry over DB attributes from outside data.
But I also need to do this without Teamcenter.
So the question is does somebody knows a way to locally clone assemblies using a mapping file and also change some attributes (like with the above mentioned method)?
Best regards
Klaus
