Do you mean
Reply
Solved! Go to solution
universal file format
I want to save my result into universal file,so that NX post can read it.But I don't know the format of universal file,who can give me some help. Whether nx open suppley method to write universal file. think you!!
Solution
Solution
Accepted by topic author ship_cheng
‎10-19-2015 10:43 PM
Re: universal file format
The universal file format is provided in the NX Documentation (Home > CAE > Advanced Simulation > Advanced Simulation fundamentals > Importing finite element data > I-deas Universal files).
There is no NX Open API to write general data to universal file format, so if you're generating your own data, you will have to write your own export routines.
There is API for post processing results manipulation functions that output universal file data, so if you are trying to export existing results data, you may be able to use those (i.e. create a result combination with a formula containing only one variable).
i find it,thank you!
