web based NX application and NX remoting
Hi All,
How to start NX remoting application. there is a sample program in the ugopen folder. but not clear.
Thanks FL
Re: web based NX application and NX remoting
There are 2 parts to remoting. You have to have nx run a compiled version of the 'server' app as shown in the documentation. This can be started manually using file->execute->nxopen in NX.
Once this is running you have to then run your external application described as 'client' in the docs.
Any calls to the 'session' or 'ufsession' classes in your remote application have to be called through the server. The syntax of this will depend on what you are writting your code in. In VB it looks like this:
Dim thesession As Session
Dim ufs As UFSession
thesession =Activator.GetObject(GetType(Session),"http://localhost:1234/NXOpenSession")
ufs =Activator.GetObject(GetType(UFSession),"http://localhost:1234/UFSession")
