How to contact board admins
I am having an issue with my account. How can I contact the board admins? I do not see any link or email addres or any other means of contact.
Re: How to contact board admins
Community Admin Community Admin
Community Admin
Hi @kjm - A Community Manager or Administrator will have a black badge that says "Admin" next to their username. What do you need help with?
- Katie
I have changed my email several times over the past 2 days. When I log back in the email is not changed.
Community Admin
Hi @kjm - you can't change your email address through the Community as that is managed by your Webkey profile. You should be able to do that here: https://www2.industrysoftware.automation.siemens.com/webkey/
- Katie
Ok thanks.
Now, when I try to change the email I get the message below. I dont know what the FlexLM License Sheet is, I work for a large corporation so have no access to any license info.
* WebKey Access Code (WAC): Webkey Access Code can be found on the upper right corner of your FlexLM license sheet.
Assuming you use NX, do a "File -> Help -> Log file"
The webkey access code will be section:
************** Licensing Information **************
 Server ID : xxxxx
 Webkey Access Code : HERE!
 License File Issuer : SIEMENS
 Flex Daemon Version : xxxx
 Vendor Daemon Version String : xxxx
 Toolkit Version : xxxxx
I would assume if you use another product, it will be in the help / about / log file there as well.
I am using Solid Edge, I do not know what "NX" is.
NX is the other CAD/CAM product Siemens sells.
So (guessing, as I don't have solid edge) in solid edge, there is a "help" menu?
Is there a "log file" option in the help menu?
Is there an "About" pick?
Community Admin
@LauraWatson do you know where @kjm can look within Solid Edge to find his webkey?
- Katie
@kjm,.....has this been sorted out for you?
Otherwise.....as has already been mentioned, go to "Help" shortcut > "About Solid Edge" link, and the information should be listed in the dialogue box, where I have redacted mine.
Try Solid Edge for free
