Do you mean
Reply
Time Data Selection
Hi there,
I try to do some psychoacoustic analysis with the add-in "sound quality metrics". Therefor i need to select a data source in "Time Data Selection". However when I put a whole section or the "Throughput" into the "Input basket" and try to "Add" or "Replace" the data, there is a error that says
"Selected data source contains no data. Current dataset did not change"
What's the problem?
Thanks for any help!
Re: Time Data Selection
Thanks for your post. It looks to me like you are using simulation/test software for psychoacoustic analysis, for example, LMS? If that's the case, please could you submit your question in the "Simcenter Test Forum":
(https://community.plm.automation.siemens.com/t5/Testing-Forum/bd-p/Simcenter_Test_forum)
(The "PLM Components" forum has been designed for software developers who use "PLM Components", so our users probably won't have the expertise to help you I'm afraid).
I hope you'll find the solution you're looking for in the Simcenter Test Forum!
Best regards,
JonR
