Drawing Sheet Delete error
Hi All,
   I am trying to delete the last 2 blank drawing sheets which are not required. But I could not able to delete them. I am getting some error message like "An attempt was made to decrement an already-zero ref count of an object." Please see the attached Image. Please let me know is there any other way to delete the last 2 blank sheets.
Thanks and Regards
VCP
Re: Drawing Sheet Delete error
Esteemed Contributor
Have you looked in the "Solutions center" database to see if someone encountered this before?
https://solutions.industrysoftware.automation.siemens.com/
If not, I woud run part cleanup on the part
- start with a new NX session
- Run part cleanup setting all the "moderate" actions (or as desired)
- run it 3 times
- save part, close & reopen
If you didn't say they were blank, I'd try deleting all views from them before deleting the sheet.
Hi Ken,
Thank you for reply.
I have tried part clean up and restarted the system. It didn't work out. Then I realized there is some issue with Group which is having curves of Grid lines of the border. I couldn't able to delete them and its only issue with the last page. One good thing is that, it was allowing me to save the file. So Just I moved views which were in previous sheets to last sheet and deleted the previous sheet and changed the sheet no.
VCP
