Only Manufacturing Template in NX while Integrating with TC
Hi Everybody
I am trying to open NX from TC, its opening but only the manufacturing template is appearing on the screen.
Kindly let me know the solution of this query. And how all the templates would be appeared.
Re: Only Manufacturing Template in NX while Integrating with TC
You need to make sure your templates are loaded in TC and that the NX PAX files are referencing the DB.  There is a lot of information on the Help to get you up and running on this.
