PLM World 2016 Presentation Template
The latest presentation template has the "gear" image running off the side of the "Thank You" slide. Is this intentional or do I need to fix it?
ImageOverrun.pngGraphic overruns slide.
Evaluating: AW 3.4
Re: PLM World 2016 Presentation Template
PLM World Member Creator PLM World Member Creator
Thank you for checking - if you view in 'presenter mode' you will see that the graphic does not show this way. This was intential to keep the graphics in original format. Please let me know if you have any other questions.
Thank you,
Kati
