Step 7 v5.5 to TIA v12 migration problem
Dear experts
I am trying to migrate a Step 7 v 5.5 PLC program to TIA Step 7 v12.
Please find jpeg below of the problem the TIA software encounters everytime at 51%.
My question is, what are possible causes of this problem and what possible solutions can I try?
I am trying to create a HMI using a comfort panel for a PLC program developed in Step 7 v5.5. The HMI panel is not supported by WINCC flex. I would like to have some sort of integration between the Step 7 v 5.5 program and the HMI I am developing in WinCC v12. This is to enable me to use the tags/DB's from the PLC program in my HMI. The HMI and PLC will be connected over Ethernet.
Thanks in advance.
Andrew
Electronic Engineer
Re: Step 7 v5.5 to TIA v12 migration problem
Hello @Andrew_ Thanks for the post. Let me see if I can find someone to help answer your question.
What Siemens software is this in regards to?
Karen Modrow | PLM World | Lead Coordinator - RUGs & Communities
Join the PLM World independent user group discussion Now!
@JohnRBaker Do you have any suggestion on this question?
-Karen
Sorry, but I'm not in a position to help with issues with respect to this aspect of NX.  Perhaps someone in GTAC or a local Siemens PLM support office.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
@Andrew_
Apologies for the delay in finding an answer to your question. This forum is actually directed more toward PLM World (the independent user group for Siemens Software) related topics, so I had to try to find some information regarding your questions.
You may be able to find more information on the topic through the Siemens website here: https://support.industry.siemens.com/tf/ww/en/threads/137/?page=0&pageSize=10
