3D Graphic Visibilty / 2D Icon Usage - based on User attribute
I have a SingleProc with a custom 3D Graphic/Icon.  It is reused in multiple places.  I'd like the 3D Graphic and the 2D icon to look slightly different based on a 'User Attribute' in the SingleProc.  For 3D it would turn on/off visibility of an embeded Animated Object, for 2D I'd create multiple Icons (?).  I am sure this can be done in a method, however, methods are triggered by a simulation event.  Would it be possible to to triger this based on the change of the 'User Attribute' (changed in the 'User Attribute' tab of the Dialog)?
DJH
Re: 3D Graphic Visibilty / 2D Icon Usage - based on User attribute
you can use an observer to do this: Tools - Edit observers, here you can select your user defined attribute and define a method to be called, if the value of the attribute changes
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Perfect! The observer concept is much clearer to me now.  Thanks!
