3D Pallet Stacking Optimization using Genetic Algorithm
Good day Forum
I'm busy developing a pallet optimization simulation and was wondering if anyone has looked at this before since it is a common optimization problem in cargo logistics?
I've found that the it is quite simple for the x/y plane (GA is currently working with boxes being created in 3D space) since I can use a tablefile to keep track of available space, but as soon as the Z axis comes into play I am not sure of how to approach keeping track of available space.
Any suggestions will be much appreciated!
Hermias
Re: 3D Pallet Stacking Optimization using Genetic Algorithm
you could use sub-lists to create the z-axis your table...
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
