3D ascending conveyour / track
Hello guys
I was playing a bit with 3D possibilities in Plant. And after the creation of first conveyor a question came to my mind Smiley Happy
I did create an ascending conveyor in 3D properties of the line object > Tab Extrusion > Lines/curves > Edit as several defined Anchor points. I think that took too much time to create only one ascending conveyor.
So my questions is ..... if there is a better/ quicker way to create such a conveyor Smiley Happy
Thank you again Smiley Happy
Re: 3D ascending conveyour / track
It is easier in the latest version.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
If you select the conveyor in the toolbox and then click into your 3D window you have a window where you can specify the height for each anchor point. So you can create the conveyor interactively, which should be much faster than using the dialog.
Ralf
Thank you RalfTobel  Smiley Happy
I found what you were suggesting. It is definitely the better way Smiley Happy
Thanks again
