3D machines library
Hello!
Did someone have a library of 3D machines different from that already has the plant simulatuion to share? If anyone has'm very grateful.
Thank you!
Re: 3D machines library
(view in My Videos)
https://grabcad.com/library is a common place to get such 3D-objects. Take care for copy rights.
For some machines you will need the original but simplified 3D-data (the first one in the video) for others, like the palettizer and the shrink wrapper (part two of the video, recorded with two different speeds) it could be enough to use Plant Simulations basic objects.
Always consider using the AttributeExplorer!
