3D rotation
as below picture, in 3d model, the graphics rotate around  the point "a"(namely the point "a" is immobile ) ,how can I realize  this ,thank you very much
Re: 3D rotation
Do you want to rotate it manually or through simtalk ?
Re: 3D rotation
can you tell me how to do it through manually and simtalk,thank you very much
Re: 3D rotation
Manually, you can use the 3D properties dialog of your object or graphic, go to the 3D properties dialog and change the rotation there.
With SimTalk, it differs whether you have a graphic or an object.
For an object, you have the attribute obj._3D.Rotation to which you can assign new values, for a graphic, you have the method obj._3D.setGraphicRotation(...).
