A question about Trigger Called Sequence
Hello  Expert,
          How to decide the called sequence of Trigger objects? I has a model, and every machine frame has a Trigger. However, the called sequence of the machine is not the same, see the attachment picture for the detail, can anyone tell me why it is?
         Thanks very much!
Re: A question about Trigger Called Sequence
I have solved, because first time the method is called by init, and other weeks it is called by trigger. Thanks.
