About AGVPool is there an example
as picture shown I try do it  but it does not work well  ,it only transport to station1 then the model stopped , anyone can give an  demo,thank you
Re: About AGVPool is there an example
I made a small example with one AGV transporting one MU, because I wanted to find out the basic mechanism.
In the Exit controls the AGV control is called. When the AGV arrives at a destination (i.e. Marker) the MU is moved and a new destination is assigned.
Gert Nomden
Digital Factory Consultant
cardsplmsolutions.com
Gert:
Can you make your model run longer? With unlimited incoming parts? I want to use your example to demonstrate to the customers.
Thank you
