About Genetic Algorithm Offspring Generation
Hello, GA wizard is a powful tool that can help me with my optimization issue.
However I wonder if there are some documents that explain the inner mechanism that the GA in Plant Simulation generates new offsprings and how it codes and decodes the variable ( take the tsp as an example: the sequence task) in to chromosomes.
The inner context help doesn't say much about the inner mechanism and the codes provided in the frames are difficult to understand.
Thank you for your kind help.
Re: About Genetic Algorithm Offspring Generation
Hello Eason,
you could have a look at the example collection. Next to many examples explaining the use of the GAwizard there is also one in there called "Basic Objects of GA" that shows how the inner objects of the GAWizard work.
Kind regards,
Igor
Hello Igor,
Thank you for your kind help. I will dig deeper into the examples and I find out more info on GA  in the help part and it helps a lot.
