About shifts and drain stats
Dear community,
I have a simple question about drain stat throughput per day. I made a simple model to point out the question. I think i'm missing something here.
The model runs for a seven days and the Source produces a part in every hour:
If the shiftcalender is not assinged to the drain:
total throughput : 118
throughput per day = 16.86 -> makes sense because the total throughput is diveded by 7
If the shiftcalender with two shifts is assigned to the drain:
throughput per day = 35.40 -> Where this value comes from?
I would like to know what two shifts are producing daily on workdays. Of course i can calculate that from total throughput but then i need to exclude weekends manually.
Toni
Re: About shifts and drain stats
Toni,
Please take a look at the Help-file for statThroughputPerDay. I think it is better to use statThroughputPerHour.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
