Access Violation: opening/closing pipes
I am using observer on a Fluid Drain's "Failed" property.
When it is failed, I open the "Fail_pipe" and collect incoming material in a tank (and closing the P-pipe).
When it is not failed, I close the "Fail_pipe" and open the P-pipe. This is what gives me access violation on row 39:
Is there a known cause? (I can not post the model due to NDA.)
Thanks in advance.
Re: Access Violation: opening/closing pipes
Please update at least to the latest release of Version 13 which is 13.2 ... I'm pretty sure the issue will already be fixed ... in case it's not, let me know.
Always consider using the AttributeExplorer!
