Active X not working on new laptop
I have just bought a new computer and have installed Plant Sim but the ActiveX object is refusing to be activated. It comes up with the following message:
The ActiveX control could not be started.
My license does have the interface package and the model works on my old laptop.
Any ideas?
Re: Active X not working on new laptop
is the object you are trying to call through ActiveX also present on your new computer?
Kind regards,
Igor
