Addressing Mu's
Builder
Builder
Hello everyone,
I have 3 same Mu's in a store but i want to move only one of it. how can i address that only one Mu should move to successor.
i wrote the following program
is
i:integer;
k:integer;
do
for i:=1 to store.Xdim loop
for k:=1 to store.ydim loop
if store.pe(i,k).cont /= void and store.pe(i,k).cont.name = "Variant_A" then
Store.pe(i,k).cont.move(drain);
end;
next;
next;
end;
With this program all the 3 Mus are moving
Could anyone help me please
thank you
10 REPLIES 10
Re: Addressing Mu's
Like this?
Store.MU(1).move
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Re: Addressing Mu's
Builder
Builder
yes but how can i write it in my program above?
In the store ia have 3 Mu's with the same name Variant_A, but i want to move only one of them
Thank you very much
Re: Addressing Mu's
You write it exactly like Gert Nomden told you:
Store.MU(1).move(Drain);
If you want to move a specific type of part, and if you have version 12.1 or newer, you can write it like this:
Store.findPart("Variant_A").move(Drain);
You should check though if there is a part (or specific type of part) by comparing the result with void. In SimTalk 2.0 the code looks like this:
var part : object := Store.findPart("Variant_A")
if part /= void
    part.move(Drain)
end
If you have version 12 or older, you can use your program. You just to need to add one line behind the move statement. That line is:
return;
Re: Addressing Mu's
Builder
Builder
Thank you Michael
But i wrote the program in following format.
is
i:integer;
k:integer;
do
if store.pe(i,k).cont /=void and Store.pe(i,k).cont.name="Variant_A" then
store.pe(i,k).cont.move(drain);
end;
next;
next;
end;
I couldn't able to use MU as it is showing unknown identifier.
Is there anyway by changing the above program i could fix it
best regards
Re: Addressing Mu's
Like I said: You just need to add "return;" behind the move.
Re: Addressing Mu's
Builder
Builder
Thank you very much
Now also all the 3 parts which have name variant_A are moving. But i want to move only one part out of 3.
Actually my store receives 3 parts of Variant_A and i want to move only one part and remaining should stay in the store.
Best regards
Re: Addressing Mu's
Hi gopi,
You need both the return statement to be in place (to end the loop as soon as it found a correct part) AND trigger the method once. If you apply this logic in an entrance control, every item will be moved.
Gert Nomden
Re: Addressing Mu's
Builder
Builder
Hi Nomden
Could you please have a look at my model once. i couldn't able to fix it.
the method is next to the store.
thank you very much
best regards
Re: Addressing Mu's
...cont.move(Drain);
return;
Your return is placed before the move comman. It should be after, otherwise you exit the method befor the move is done.
Gert Nomden
