Adjusting the table index with a method
I am looking for a way to adjust the table index with a method. I want to use a constructor method to list all derivations of one object in a list.
But unfortunatly xDim or yDim does not work. This is my current method:
is
do
current.Auflistung_AK_Inhalte.writeRow(current.Auflistung_AK_Inhalte.xDim+1,0,?.name);
end;
Is there a different way to adjust the table index with a method?
I appreciate every suggestion! Thanks in advance!
3 REPLIES 3
Re: Adjusting the table index with a method
the most simple way to get a table of all derivates (children) of an object is to do a query with an AttributeExplorer ...
Always consider using the AttributeExplorer!
Hello Eventdebugger,
thank you for your answer.
But my problem is not to get a table of all derivations. I want to know how I can add values to a table index with a method. In my case I want to add all derivations of one object to my table index.
But unfortunately, I cannot use xDim or yDim to add generically the names of the derivations. Do you have an idea how I can solve this?
Thanks again!
BR
Ok, I got it.
I used path.xDimIndex
