Aerospace engine modeling in 3D
Dear All,
I am doing aerospace engine process line modeling in 2D. But I should do 3D model as well.
I could not find a suitable sample regarding aerospace industry modeling.
Anybody can share with me an example for aerospace engine simulation modeling?
I think It would be  a 3D model make up (edit Icon) issue..
Thank you,
Sumin
Re: Aerospace engine modeling in 3D
Hi Sumin,
With the latest Plant Simulation version you can import several 3D formats, but JT probably works best.
Other than that, it depends a bit on what is important for visualization. Is it the surrounding factory itself? Or parts being added to the engine?
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Hello Nomden,
Thank you for your reply.
If I would like to show the surrounding factory itself, is it possible only using "Edit function" in3D plant simulation?  Do you have any sharing idea ?
Thank you,
Sumin
For 3D modeling specially when factory surroundings are involved the best is to import from a CAD system.
Plant Sim is not intended for modeling 3D layouts itself nor product. 3D data usually comes from outside sources.
So before modeling I would suggest you find and retrieve this data.
cortega@interlatin.com.mx
+52 (81) 10801310
InterLatin S de RL de CV
