Alternative services
Good afternoon everyone.
I have a problem with the services of a SingleProc.
I defined a service, the number of people, and an alternative if there is currently no availability of that service, but the alternative service is not being activated.
Could anyone explain?
Re: Alternative services
Add the alternative service in the 2nd row and write "Alternative 1" in the last column. When you write "Alternative" in the last column then the first column service it corresponds to a alternative service.
Sachin
Thank you very much.
