Animation path in 3d viewer
Same as SG, I could not implement the explanations on SG's file, in order ot see the MU's (in lower level frame)  on a machine defined in an upper frame.
I appreciate if you can complete SG's file.
Shai Weinbren
4 REPLIES 4
Re: Animation path in 3d viewer
here you go.
I´ve updated your model to work ( s. attachment).
What I noticed, was :
- 3d objects in the machine frame  were completely switched off  (no link to 2d)
- you created animation paths directly in the machine frame, hoping the Mus would move on them, which they won' t, as they are dedicated to the 2d-objects (which were switched off).
Just to show you, how it works, I´ve switched off the station graphics in the machine frame
Sorry
sorry but i could not get you.
I have probably basic misunderstanding. I am trying to see the 3D view of the frame111 by opening the 3D of the 2D frame111, with anything inside.
See attached file
If I got it right , the graphics in the frame111 are switched off. select the appropriate 3D-node (machine or frame111) press cntrl 3, select tab "visibility" and switch on "visibility content"
