Assembly Problem
Hi, Guys,
i made a simple model, how to make the MU move to the Line from AssemblyStation?
Br.
Jill
Re: Assembly Problem
the connector is sufficient in your case, you dont need an exit control; the main part will be moved after the assembly process; the model is working
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hello, sir!
I also do this model and I have a question whether the code I write to  define destination of PickAndPlace is right.
Could you please also have a look?
That Pallet A all go to Line1, and 50% of Pallet B , 90% of Pallet C go to Line1, as the others go to Line11.
I will really appreciate!
