Assembly exit failure
Hello Community,
I have encountered with an issue this morning, and I would like to get some feedback.
My scenario is the following:
I have 5 different sources of pieces (Lets name them Cor1, Cor2 .... Cor5), and I want to assemble them to get a resultant product (EnsCor).
After producing an MU, each Source has a buffer, then it goes into a function that assembles them.
When the Assembly recieves the 5 different pieces and assembles them, it does nothing, should I add something to exit control or do you have an idea of what sould I do?
I attach all pictures and my little simulation.
Thanks for your time.
Re: Assembly exit failure
two little failures: the main part (from predecessor 5) must not be part of the assembly table and the assembly table contains the names of the mus not the path
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Exactly what I needed, thanks
