Assembly line
I want to simulate a packing line. The MUs come from 2 line and then a packing machine does a 12MU pack. Why the assembly didn't work in this example? Thanks.
Re: Assembly line
Hello João.
Sorry not answer your previous question time.
You have set the 'Assembly' incorrectly.
In 'Main MU from predecessor' you should put a source will be the main MU mounted block.
Can not send your corrected example cause my PS version is 12.1, so you could not open.
If anything happens, let me know.
Henrique Martins
Re: Assembly line
there were several parameters not set correctly for the assembly station.
eg.: no container set to load 2 X 6 entities
please check assembly station attributes for all details
