Assembly of 3 products
i have a student version of Plant simulator 12, and i need to assembly 3 product in one assembly station - 2 product was assembled before and now simulation stuck at last assembly station (Montaz_V). Last MU from Montaz_V should consist of 1 MU from Zasobnik_V1, 1 MU from Zasobnik_V2 and 2 MU from Zasobnik_B.
Can you help me please?
Re: Assembly of 3 products
the linkages to the last assembly were mixed up
Thanks a lot. I really didnt notice that. Did you use some kind of debugger or just went linkage after linkage? Im started work today in this software i will be glad for any kind of advice. Thanks
You must enable the option "See predecessor". Then you can see that your Setting was "Main Part from predecessor 2" but your main part had actually the number 1.
