Assign delivery table to source
Hi all,
currently I'm trying to assign a delivery table object to a source. First, the delivery table is filled by using an algorithm and needs to be assigned to a particular source, secondly. Unfortunately, I do not find the appropriate SIMTALK command to do so.
In German version I tried
- Quelle.erzeugungszeit := "Lieferliste"
- Quelle.erzeugungsTabelle(Tbl_Lieferliste)
As the second command changes the attributes of table "Tbl_Lieferliste"  I'm assuming that this is not the right way. By changing the delivery table manually during simulation, everything is fine.
I'm looking forward to your responses.
Cheers
Ben
Re: Assign delivery table to source
the second attribute is path (Deutsch: pfad)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you very much! It works fine for me.
