Assign value for User Defined Attribute
Hello everyone,
I try to auto assign value for a list of user defined attribue of object such as:
For i:=1 to n loop
For j:=1 to m loop
str_to_obj("A"+i+".B"+j) := 0;
next;
next;
In which:
-A: point to the path such as the transporter named "A'
-B: name o f the user defined attribute (Type: integer);
However, it doesnot work. Is there anyway to do it by a list or we have do it manually?
Thanks.
Re: Assign value for User Defined Attribute
you can use the method setAttribute and you need to transform the numbers to strings
For i:=1 to n loop
   For j:=1 to m loop
      str_to_obj("A"+to_str(i)).setAttribute("B"+to_str(j),0);
   next;
next;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
you can make this work by setting the atribute B with setAttribute in this way:
for var i := 1 to n
 for var j := 1 to m
  str_to_obj("A"+i).setAttribute("B"+j,0);
 next
next
Best regards,
Igor
Kind regards,
Igor
