Re: Assigning failure parametres by method from a centralized table
is
do
    local path : string := "SingleProc.Failures.Failure";
    local type : string := "Uniform";
    local para : string := "1, 5:00";
    execute(to_str("is do ", path, ".Duration.setTypeAndAttr(\"", type, "\", \"", para, "\"); end;"))
end;
