Automatic mediation
Hi everyone,
I was playing around with the AutomaticMediation attribute. In my model, Exporter 2a and 2b the attribute is set to false. However,they still get mediated by the Broker anyway, although I have no controls for that. I must be missing something, but it does not get clear from the documentation...
Any ideas?
Gert Nomden
Gert Nomden
Digital Factory Consultant
cardsplmsolutions.com
Re: Automatic mediation
sorry, this is a bug. Up to now this attribute only works for worker not for exporter.
The bug will be fixed in version 12.0.3.
Kind regards,
Karola Mock
