Automatic routing spanning over different frames?
Hi all,
We are currently modelling a scenario where the factory is modularised built in different subframes. Furhermore we would like to introduce a truck which performs logistic operations carrying parts from one frame to another.
So far, I haven't succeded using the automatic routing when the truck operates over several subframes. The roadnet is built up by "TwoLaneTracks" with interfaces connecting the tracks from different frames.
Any ideas?
Johan
1 REPLY
Re: Automatic routing spanning over different frames?
Never mind, the problem was due to a missing connector. The automatic routing logic works even for objects within other frames. As long as they are connected to the same roadnet for which your AGV/Truck is operating
Johan
